disable tech-support collector
Description
Disables the tech support feature.
Syntax Description
Default
Disabled.
Usage Guidelines
This command disables the tech-support feature. In the ExtremeXOS 15.4 release, the feature is disabled by default. When the feature is disabled, the previous scheduled reports are canceled, and the bootup event and critical severity events are ignored.
The following command disables the tech-support feature:
This command was first available in ExtremeXOS 15.4.
Platform Availability
